How to make databases in Labview?
Hi all,
I have designed a labview code to test some hardware and i want to store all the results of test in the form of table in MS Excel file. Please guide me how can i perform this task...
Kind Regards
Zaib
(4,766 Views)
The simplest is the use the "Write to Spreadsheet File.vi"
Dan Shangraw, P.E.
(4,741 Views)
Thanks for response.
Kindly tell me that how can i access database in labview?
Kinds Regards
Zaib
(4,714 Views)
Have you tried doing a search of the forum? There are numerous references to the Database Connectivity Toolkit which makes it simple for a beginner and LabSQL which requires a bit more knowledge. There are posts on using the low level ADO properties and methods and even (shudder) MS Access and ActiveX.
Your topic and first message are confusing since a database is not Excel and vice versa.
(4,711 Views)
Sory sir actually i wanted to get information about both queries..
(4,695 Views)
