How to make 'else' case in case structure conditioned by a string ?
In building a case structure conditioned by 'string', how can I make the last case slide cover all other cases, other than the option choosable ? Just like the else statement in the text based programming language.
(4,734 Views)
They have supplied a way to mark what the default case is. The keyword is "Default", so if your last case was for a string "No" then the selector at the top of the case would look like
"No", Default
and this would become the default case.
(4,734 Views)
If you set it as default, it will execute if other cases don't match.
Good luck
(4,734 Views)
