How to make menu ring items visible through VNC ?
I have an application that has a menu ring in it. I am compiling the app., distributing it to a remote system, and viewing it using VNC (3.3.7) . Everything works through VNC with the exception that I can't see the items on the Menu Ring when it is selected (if I select the Menu Ring through VNC I can see on the host computer that it does cause the ring to drop down). I saw the item in the discussion forum regarding disabling the menu animation - I did this and recompiled the app., but this did not fix the problem.
(2,572 Views)
In the VNC configuration, try "refresh entire screen" It really slows things down, but it gurarantees that every item is actually read.
Eric
Eric P. Nichols
P.O. Box 56235
North Pole, AK 99705
(2,572 Views)
