How to make multiple telnet connections in Labview server ?
Dear National / Community,
I need to know if the following scenario is possible, in labview 7.1.1 (Windows XP):
A Labview telnet server, that can make individual point to point connections with multiple clients, up to 9 users.
The program needs to have the option to process and decode al the data from all clients instantly, preferably paralel-processing.
Is this possible, and is it possible to let all clients run at the same portnumber as the server is ?
All comments are welcome !
Kind regards,
Ronald / The Netherlands
(3,359 Views)
Hi Ronald,
Yes, I believe it is possible to create such an application. You would need to use the regular TCP/IP functions with in LabVIEW to accept connections from Telnet clients and react to them.
More information on the TCP/IP functions: Basic TCP/IP Communication in LabVIEW
You can connect to a TCP/IP Server running on the same machine using the local loopback, enter either enther localhost or 127.0.0.1 as the IP adres.
A good example that ships with LabVIEW is the: 'Multiple Connections - Server.vi' with the Multiple Connections - Client 1 and Client 2 VIs. you can find them by searching the NI Example finder with keyword: 'tcp/ip'
Hope this helps,
Karsten
NI
(3,347 Views)
