How to make one case structure with several conditions?
Hallo everyone;
I want to do the following, one case structure inside a for loop connected to it the following conditions, when i = 1 then do something, when i = 2 do another thing , when i = 3 ..... till i = 5
i can do it with 5 case structures but i want to know if its possible to do it with one and how?
thanks
(2,970 Views)
Wire the integer value to the case selector and have as many cases you want. Generally Enum data type is used for this purpose.
(2,966 Views)
When you wire a numerical input to the case structure, you would orignaly have two cases
ex: I wire the case structure terminal to 'i' value of the For loop. then, the cases i have will be, '0, default' and '1'.
right click on the case strucutre, select Add case after. you will get a new case of i=2.
right click again and repeat to get as many cases as you want. if you want to change the case value, to example 12 instead of 2, delete 2 and enter 12 there.
Regards
Freelance_LV
TestAutomation Consultant
(2,963 Views)
Hi valdi,
did you consider reading the context help for the case structure? It explains all the details...
(2,941 Views)
