How to make overlay around the boundary of an image?
hi,
How to make an overlay around the boundary of an image.
Dibya
Message 1 of 8
(3,646 Views)
Hi Dibya,
can you please show what you mean? Do you wanna hide the border? Please explain.
Mike
Message 2 of 8
(3,636 Views)
Suppose one Character is there,Ex-8,i Want to overlay around the boundary of the 8,not full Character.
Message 3 of 8
(3,622 Views)
Hi Dibya,
i'm still not really sure, but if i understand it correct, then you can use the image functions to draw over the loaded picture.
Hope it helps.
Mike
Message Edited by MikeS81 on 06-18-2009 08:33 AM
Message 4 of 8
(3,617 Views)
If you want to overlay 8 feed top,left  : bottom,right to overlay rectangle. If you are using a pattern matching the u can do this. If u want to overlay 8 then u might need to use Imaq overlay points and u need to pass on array of points.
Message 5 of 8
(3,613 Views)
Not the rectangle amtalking,am talking about boudary of an character.Overlay should happen only on the outer part of the image.
Message 6 of 8
(3,594 Views)
Ya mike,u r correct that by using Imaq overlay point i can do,before that i want that array of points having only outer bondary points.can u help me to find the point on the boundary or outer part.
Message 7 of 8
(3,592 Views)
one way of doing it.
Message 8 of 8
(3,573 Views)
