How to make "Enum Control" disabled during run-time of an executable application, and make it enabled when application is stopped/aborted?
Just remember at you could never use that Abort button in a exe, unless there is a bug or critical error with your code.
Using the abort button is like stopping your car with a tree. It works, but the car might not drive again.
You should have prober design of your program, that allows the user to enter data before the program is continueing.
You should also have a correct way of stopping the program, so that is can close down in a orderly maner.
Message 11 of 18
(2,113 Views)
Yes, sure, I will use stop button to abort exe.
Regards
Jamal
Message 12 of 18
(2,104 Views)
Regards
Jamal
We should get our terminology right.  Stopping the VI gracefully by letting it complete is not the same as aborting it.  And by "stop" button, i hope you are refering to a button you place on the front panel named "Stop" and not the abort button.
Bill
CLD
(Mid-Level minion.)
Message 13 of 18
(2,090 Views)
Yes, exactly. I mean a button placed on the front panel of executable application to stop application.
Message 14 of 18
(2,064 Views)
Could you pls explain "how to disable abort button permanently"? so that only a stop button could be used to sbort application.
Regards
Message 15 of 18
(2,061 Views)
Accepted by topic author Mr_Engineer
Message 16 of 18
(2,059 Views)
@Jamal_IE wrote:
Thank you.
Regards
Hey, sorry - I didn't mean my other post to sound so terse.  🙂
Bill
CLD
(Mid-Level minion.)
Message 18 of 18
(2,031 Views)
