How to make scales equal when zoom out option used in system XY graph?
I am using X-Y graph to plot an array. Since the array represents the goemetrical figure, it is good to have both X and Y axis equal. I did that using proferty nodes of X-Y graph.
Now, when I zoom in and zoom out the graph, scale looses it's property. I was just checking for event in the event structure for zoom out option of the graph so that I can make the scale equal whenever zoom out button is pressed. But I couldn't find any such.
I request your suggestions to solve the issue.
Thank you
(2,793 Views)
there is an appropriate event.
I only have the german version available so I'll translate from there: Change of scale range (Änderung des Skalierungsbereichs).
Hope you find it.
Florian
(2,757 Views)
