How to make the LED light blinking at a given freguency?
Hi. All,
I worte a labview program to turn on a LED light using the analoge out voltage in PCI-6030E daq card.
The driving voltage can be set to 3.5v to turn on the LED.
Please see my attached labview 8.6 program.
Now, I hope to make (or modulate) the LED blinking (switch on and off) in likely 100Hz or even faster.
How should I modify my labview program?
Thanks very much.
Rogers
(7,719 Views)
Put a shift register on the loop border.  Wire in a 0 to intialize.  In the loop, put in a delay for however many mS you want the LED to toggle on and off.  Put in a case statment.  If shift register value is below 1 (don't use equal on a floating point number), then change the output to 3.5.  If not below 1, then change the output to 0.  Wire the output of the case to the shift register on the right side and to the data in of the DAQ assistant.
I don't have LV8.5 so I can't code your vi.  But here is a snippet showing the code:
- tbob
Inventor of the WORM Global
(7,713 Views)
Thanks for the suggestion. I will check it and let you know the results. Cheers~
(7,674 Views)
You could also create a square wave and pass that to the DAQ Assistant.
(7,667 Views)
I also tried this, however since any current between 3 and 3.5 volt can turn on the led in a different brightness. When the square wave changing the state, the LED didn't really turn off.
Since the LED provide a lumination for my camera. I do see some brightness changing in square wave modulating. I need the LED on/off change sharply.
Thanks.
(7,657 Views)
Dennis's method should work.  How did you generate the square wave?  You should be able to set the high voltage and the low voltage individually depending on how you generated the square wave.  Use the Analog function for generating a square wave, not the digital function.  With Analog, you can specify the voltage level exactly.
- tbob
(7,647 Views)
