How to make the cluster transparent keeping only Elements inside the cluster visible?
Can anyone suggest me how to make the cluster transparent keeping only Elements inside the cluster visible in the Front panel.
Thanks in Advance,
Venky
(5,850 Views)
Have you tried a search? This has been asked and answered many times. Use the paint tool. Place it over the cluster border, right click and select the "T" symbol in the upper-right. Use the spacebar to toggle FG/BG.
(5,848 Views)
Hi Smercurio,
Thanks for your immediate reply.
I think my question was not clear enough,actually i even want the cluster border to be transparent.
Venky
(5,842 Views)
Accepted by topic author VENKATESH.J
As I said, use the spacebar to toggle what it's painting. It works. Trust me. Smiley Wink
P.S. You cannot link to images saved on your hard drive. We cannot see them. You must add them as attachments and then submit the post so they get uploaded to the NI servers.
(5,839 Views)
Hi Smercurio,
Your Absolutely Correct. It Works cool.
Thank you,
Venky
(5,837 Views)
