How to make this function >>random chose bits and flip it
Hi ni and member
I try to make this vi that do this function
I need it to use in academic research
I have  stream of bits  have length=100bitsmove in serial
and I want a selector that select between ratio  0.1 0.2 or 0.05 that represent error ratio
its ratio of bit that much flip (0 to 1) and (1 to 0)
for exqmple
for 0.1 ratio 10 bit of stream must randomly chosen and flipped
for 0.5 ratio  50 bit of stream must randomly chosen and flipped
any help please
best regards
hi ?Q>
(2,454 Views)
Hi mangood,
- use a ring or enum for your selector
- depending on the selector value create a boolean array containing randomly set bits
- XOR your boolean array with your stream bit array
Done...
(2,448 Views)
@GerdW wrote:
Hi mangood,
Done...
thank you with kudos
i did not understand the stament """use a ring or enum for your selector"""
can you make a pic for the vi
best regards
hi ?Q>
(2,439 Views)
Hi mangood,
when placing a control on your frontpanel you could use a ring or enum found in the "Rings and Enum" control palette...
(2,419 Views)
