How to make two signals separated
Now I'm using NI 9215 with BNC to acquire the data. I have two channels come in, but the problem is when I using DAQ Assistant.vi, there is only one channel output, I want the two signals can be separated(Two channels output).
Anybody can help me?
(3,172 Views)
If I under stand what you are asking you would use the "split signal VI"  In the signal manipulation pallet.
Alan
(3,163 Views)
Where it is?
I couldn't find it
(3,147 Views)
See the little 'Search' button on the functions palette? Use it.
p.s. Express>Signal Manipulation.
(3,141 Views)
Accepted by topic author LeoLiu
In the functions group, under "express" it is under the signal manipulation (looks like a rubiks cube icon)  it is the one called "split signal" I have used it with the Daq Assist.
Alan
(3,140 Views)
