How to manage a case structure Untill a value is reached
Dear all,
I am collecting data with DAQmx and after a value is reached i want to do smthg else, for this reason i created a case structure and i put to the case selector that if a value is smaller than "10" then it is true. If it is false it should stop and do what i say even if the value gets under "10 again".
 So how can i make this: "once the value is reached then do what i say  even if  the case selector value is back to true state after a while"
Thanks.
Kind regards.
(2,523 Views)
You can use the shift register to make a condition so once it enters into the value greater than limit case then it will not go to the other case even if the value goes below.
(2,510 Views)
Accepted by topic author Salander
Hi
Check the attached VI.
Nitz
(Give Kudos to Good Answers, Mark it as a Solution if your problem is Solved:smileywink:)
(2,505 Views)
Thank you so much guys, you are the best!
(2,486 Views)
