How to manually set the point to xy graph
I have some problem with how can i manually set the point into XY graph. The point is definition by myself, actually i´m doing an experiment that i use function generator to set with different frequency, like(100, 300, 800, 1400...Hz), and at the same time i still need collect the voltage signal from lock in ampliefier. At last i get a XY graph, X for frequency and Y for voltage. Voltage signal as mesurement signal is not stable. I just want to collect the signal under the best situation, then put it to XY graph.
(2,757 Views)
It is not clear at all what you want to do and what you mean by "manually".
  • You could convert the mouse down coordinates to plot coordinates and define a point
  • You could use a cursor to define a certain frequency
  • etc.
(2,734 Views)
