How to match dynamic waveform to a sample waveform?
Hi
My proposal is to check the signal from some pins of a microchip, under different status the chip will output different waveforms, so I capture a sample waveform as a pattern, and then I want to continuously acquire waveform from microchip to match the pattern and them trigger LabVIEW event..
How to deal with this?
*The best Chinese farmer*
(4,304 Views)
You can use an Event Structure [ES] configured inside a while loop. Either in the ES' timeout event or in some other event configured for a Front Panel Boolean control [say, Acquire], you can put your acquisition code for getting the waveform continually.
Then you can have a Compare button under whose value change event you ll do the comparison of the sample & acquired waveforms. Here, you should trigger the other LabVIEW event you want using the Value(Signalling) event for that control.
Please explore the NI Example Finder thro' Help -->> Find Examples under the title "acquire"; you ll find a lot of examples.
- Partha ( CLD until Oct 2027 🙂 )
(4,293 Views)
Hi parthabe
Thanks, I'm aware of how to trigger event in ES, now I'm just seeking a waveform analysis arithmetic or a match pattern vi, I don't have a good thread on this.
(4,276 Views)
See my captured patterns.
帖子被paulbin在10-10-2007 09:18 PM时编辑过了
(4,267 Views)
Use the Digital Comparison.vi i the Waveform -->> Digital Waveform pallette.
(4,263 Views)
The graphs are acquired by AI, those are not regular digital signals, the waveform transition at 1.5V, 3V and so on. So I can't process these signals by digital VIs.
(4,247 Views)
hi ,
  I have same problem in my test project, so i  am very  interested in your discuss.
 Pl keep up it : )
Sonic
Diffrent Strokes for Different Folks
(4,234 Views)
