How to matlab script and labview Let the programs work together
The current issue I'm encountering with using Matlab scripts is that it fails to work when receiving values from a global variable. The reason for using a global variable is because I'm receiving accelerometer data through MyRIO and then passing it to the program named "FFT" via a Recent File node. Afterwards, I'm sending it to the Matlab Position program, as indicated in the attached file.
(1,068 Views)
Hi Output,
the error message is quite clear: the Matlab node is not supported on your myRIO realtime target…
Do you think it's a good idea to run greedy loops on your myRIO? (FFT.vi consists of two greedy loops!)
What's the point in running your Matlab node in a greedy loop?
(1,061 Views)
HI Gerd W thanks for solutions.It means that you can solve the problem by installing the software shown in the image I provided, correct?
(1,052 Views)
Hi Output,
What do you try to install?
You cannot use the Matlab script node on your RT myRIO target. Point.
(1,048 Views)
