How to maximize heat from cRIO fpga for test
Any guidance on creating a Labview FPGA program that will make a cRIO FPGA run hot (i.e., lot's of gates switching at high frequency)?
We'd like to see how hot we can get our cRIO for environmental testing.
Steve
(2,881 Views)
Why don't you just create lots of while loops, toggling a boolean in the shift register.  Make as many as will fit.
Machine Vision, Robotics, Embedded Systems, Surveillance
www.movimed.com - Custom Imaging Solutions
(2,848 Views)
Thanks for the idea.  I think I would need hundreds or thousands of while loops but prompted my thinking; I create a huge array and continuously update it in a while loop...
Steve
(2,822 Views)
Steve,
what is the purpose of your question?
Does it refer to: What is the maximum power consumption of the cRIO (which is most likely emitted as heat)?
Or does it refer to: What is the maximum external temperture cRIO can still work without creating unexpected issues?
In both cases, you should first consult the specifications file of the cRIO as NI states values for both questions.
Norbert
Norbert
Expert: Geometry
(2,820 Views)
I have seen the specs.  We want to see actual results in a test chamber that simulates our operating environment.  We're going to run on a balloon at 40km altitude.  Anyone done similar with a big cRIO (we have a 9082)?  I've seen the white paper from NOAA of the cRIO but it's an older, smaller cRIO.
Steve
(2,814 Views)
