How to measure a frequency by NI USB-6008?
Hi,I want to measure a 40K frequency by NI USB-6008? I don't know if USB-6008 can come ture.
(2,552 Views)
Accepted by hu5201314
I'm assuming that you are experienced in LabVIEW.  The 6008 has a Counter/Timer that can be used to estimate the frequency (or period, depending) of a periodic signal.  You might even find some Example code.
(2,538 Views)
If this is analog signal, you can not - USB-6008 can only sample at 10kHz. If it is large enough and goes out of TTL thresholds (or digital signal), counter can help.
(2,436 Views)
