How to measure maximum voltage of channel 1 and channel 2 simultaneously in Agilent oscilloscope DSO 2002A?
Don't branch the VISA Resource wire or the error wire. Just call the functions one after the other.
Message 11 of 21
(2,151 Views)
As per your suggesstion i tried in that way also. Again i'm getting the same problem. it's not reading channel 2's voltage instead it is reading channel 1.
Message 12 of 21
(2,139 Views)
Please show your modifications.
Are the separate measurements shown on the scope's screen?
Message 13 of 21
(2,130 Views)
yes, i can see the separate output in the oscilloscope screen. it is reading both channel 1's and channel 2's maximum voltage separately.
Message 14 of 21
(2,125 Views)
I don't have driver but I believe the Read Measurement function should have an option to pick the specific measurement. What does the help say?
Message 15 of 21
(2,118 Views)
There is no problem in read measurement function. when i measure channel 1 only, it is reading channel1's maximum voltage correctly. when i measure channel 2 only, it is reading channel 2's maximum voltage correctly. there is no problem in that. the problem is when i try to measure both channel 1's and channel 2's simultaneously. i think the problem may be in configure measurement type (while configuiring source channel 1 and channel 2).
Message 16 of 21
(2,099 Views)
Then perhaps you are using the wrong polymorphic instance of the function. I would suggest you look at the SCPI commands that are on the block diagram and compare them to what is in the manual.
Message 17 of 21
(2,084 Views)
i tried in all way. i couldn't solve the problem. herewith i have attached the BP of my program (tried in both parallel and series way). i'm getting the same output. i have a doubt in 'read measurement' function, it is asking measurement type only. then how it will take the channel. if i give source channel 1 and 2 in configure measurement type (separately for both channels), it wil go to default as channel 1 while i runing the program. that is the problem. i dont know how to rectify that.
Message 18 of 21
(2,060 Views)
And have you tried a different instance like I suggested? This is done by clicking on the polymorphic selector below the function. Have you tried looking at the block diagram of the read measurement function, like I also suggested? Do you always have context help turned on?
Message 19 of 21
(2,022 Views)
I'm pretty sure you want something like this.
Message 20 of 21
(2,012 Views)
