How to measure te bandwidth of the signal?
First thanks for Kent Leung to answer my question.But I think the answer is not what I want.Now I clarify my question again.I have got the decrete sample data and have got the frequency domain waveform in which there are many narrow-band signals.Some signals may have two peaks.So the method Mr.kent suggested may get the wrong bandwidth.I want to measure the bandwidth of each narrow band signal.In my opinion,It is very important to choose proper reference level.I wonder if I have clarified the problem.
Thanks again
(2,775 Views)
From bsukpraphrute@yahoo.com
I have just join your question. But I have something it might be useful to you. If you took EE class, anything that below than 10 Db you can ignor. That is your bandwidth from Vp. You just care only 1 st or 2 nd harmony, but you may consider 3 rd ( but I found most of application just don't care).
Good luck. Programming I leave it to you.
(2,775 Views)
