How to minimize a VI
I don't think we'll be able to do much with just the project file.  Was your project file originally created in 8.2.1?
Jeremy_B
Message 11 of 14
(994 Views)
Yes, that is the reason I believe it is a conversion issue. When I upgraded to 8.5.1, the issue appeared.
Message 12 of 14
(988 Views)
Hi Joseph,
I've tried this again, starting with a project in LV 8.2 and upgrading it to 8.5, and still can't reproduce.  I think without your actual project, we would be unable to reproduce this issue.
Jeremy_B
Message 13 of 14
(973 Views)
You have to be careful on the changes on the way I had to minimize the vi.  Remember on 8.2.1 a bunch of the VI setup did not work, e.g., you could not change the appearance in the project file. You had to change it in the actual VI itself. Again, if you want the project file I am willing to give it to you.
Message 14 of 14
(970 Views)
