How to modify X-Net Interface Control in System shape ?
See attached what i mean.
The goal of this is that all our HMI  got "Sytem" controls&indicators... How to keep this for X-Net Controls ?
BR,
Vincent
Message 1 of 10
(6,672 Views)
Accepted by topic author Vincent90
Not all of the 'special' LabVIEW controls (e.g. VISA, XNET) have a system equivalent - my suggestion would be to retrieve a list of the values, and then use a system drop down box (e.g. ring / enum / combobox) and populate it with the list of items.
You could also create a customised control (with whatever appearance you like) or create an xcontrol which has the functionality I specified above.
(blog)
Message 2 of 10
(6,661 Views)
I suspected this to do... just would liked to be sure i didn't miss anything in system palette or whatever !
Vincent
Message 3 of 10
(6,659 Views)
There is a 'missing system controls 2.0' toolkit available from VIPM - it has many additional system style controls - there might be one in there and if nothing else, it adds a bunch of nice looking buttons etc.
(blog)
Message 4 of 10
(6,648 Views)
I just tried it. It is nice but X-NET controls are not converted.
Vincent
Message 5 of 10
(6,641 Views)
Attached the Xnet control with system UI look.
Message 7 of 10
(6,564 Views)
I had a need for a few more system XNet controls.  So I made the Database, Frame, and Signal system controls.  Again why these aren't included with XNet (along with other NI IO controls) is a mystery to me.
Message 8 of 10
(5,794 Views)
How were you able to create this kind of control?
I tried using on LV 2019 and got a broken wire.
"The type of the source is xnetDatabase. The type of the sink is XNET Database (XNET,xnetDatabase)."
Using type cast I was able to run the VI, but nothing comes out of the control and I cannot probe the wire from the control.
Message 9 of 10
(5,455 Views)
I honestly don't remember how I made these.  I suspect I started with the official XNet controls, and then went to Advanced >> Customize and replaced elements of it with the system components.  I also suspect you could use a Concatenate String (resized to only have one element in) and it should work as you need without broken wires.
Message 10 of 10
(5,443 Views)
