How to modify a datafile using file read and file write
I have a datalog file containing port and DMM setup information.  I want to read this file into an aray, update or modify it, and write it to a file.  I can read the file in, but I am at a loss on how to modify it since it is stored in an indicator.  Any suggestions?
(2,764 Views)
The simplest thing is to replace your indicator by a control, and to use a local variable to write your data into the control.
Chilly Charly    (aka CC)
(2,752 Views)
Works perfectly.  Thanks.
(2,735 Views)
