How to modify strings by deleting non-essential portions?
I am using a Labview driver for a linear stage.  To use this stage, I need for it to output the position which I can get.  However, it outputs the position in a string like the following:
POSITION=-1.2754
>PRINT "POSITION="  POS
How would I get rid of everything except for -1.2754?  Is there some type of deconcatenating feature in Labview?
Thanks!
(2,992 Views)
would this work?
Andy Chang
(2,978 Views)
Accepted by topic author Purdue17
Not sure what you mean by a "deconcatenating feature". The Spreadsheet String to Array is the closest I can think of.
I am assuming that's 3 lines that you're getting. The example shown above can be simplified to this:
Message Edited by smercurio_fc on 04-12-2010 04:18 PM
(2,973 Views)
