How to monitor wireless signals in a room using LabView
Ben wrote:
It would about that time that you should expect them to observe;
But how can he observe when he is in the chamberSmiley Wink?
Perhaps the $15K for the VNA would be better spent on therapy?
I thought OP is the therapist, trying to confront his client with physical facts.
An USRP can scan the entire spectrum up to x GHz (depending on the model). However, the bandwidth is limited so the spectrum has to he 'scanned'. I'd think a VNA does it the same way, but might be wrong.
Theoretically, a really bad sampling device would work. One that does not have an input filter. Normally, when you same 0-1MHZ, you'd filter so nothing else comes in. But if you filter (let's assume a perfect band pass filter) 0-2MHZ, and you sample it with 0-1MHz, the 1-2MHz will show as wrapped frequencies (1-0MHz). USRP's work like that, they filter from x to x + bandwidth, and sample with bandwidth. So if you don't filter at all, you will see signals from the entire spectrum, but with the limited bandwidth and without knowing what frequency the signal is. I'm no expert, but that should more or less how it works. I'm not sure if an USRP can be set up to not filter at all, or if other devices like that exist. An electrical engineer will probably be able to make this without any problems.
Message 11 of 37
(2,854 Views)
Too easy.
Using LabVIEW you can not only Acquire and Analyze but you can also Present. Smiley Wink
Save the sweep to file.
Ben
Message 12 of 37
(2,845 Views)
@Ben wrote:
Too easy.
Surly a proper conspiratorialist won't fall for that.
Message 13 of 37
(2,839 Views)
wiebe@CARYA wrote:
@Ben wrote:
Too easy.
Yes, sadly even a 21-CFR-11 compliant application (admissable in a trial) may not be effective.
I have talked to psychotics in my past and found that as soon as I talked them into a corner, they changed the subject. Perhaps looking to LabVIEW and hardware may be a case of "everything looking like  nail" when the proper tool is antipsychotic drugs.
Spoiler
Reminds me of a quote from an old Memorex disk drive maintenance manual that read "attempts to get the device to run error free is an exercise in futility."
But then again...
The RF chamber and VNA can be used to demonstrate how wrapping the cell phone in tin foil is effective shielding. In that case aluminum foil skivvies may be an acceptable option for the skeptical one.
Ben
Message 14 of 37
(2,833 Views)
A VNA uses a phased locked signal to do an analysis of transmitted and reflected signals.
That's not what he needs.  He needs a very wide band spectrum analyser.
Luckily they are a bit cheaper..
http://www.ni.com/webcast/3693/en/
Tin foil hats are even cheaper yet..
Message 15 of 37
(2,821 Views)
I stand corrected!
Message 16 of 37
(2,815 Views)
Gotta get the science right here or this just won't work.
Message 17 of 37
(2,809 Views)
Also don't forget that a smartly contrived body monitoring bug would spend most of its time quietly recording whatever bio-signals it could and only transmit the info back to the mothership in a quick burst when it detected the subject was sleeping.  So make that faraday cage nice and comfy!
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
Message 18 of 37
(2,787 Views)
Guys.  Stop trying to confuse the original poster
The simple fact is that all space based monitoring of human subjects practiced by them today employs neutrinos.  Placing the subject safely within a body of 2 kilometer sphere heavy water chilled to or below 2K is the only feasible means of preventing monitoring from the outside
Spoiler
No guarantees on subject survivability
Message 19 of 37
(2,776 Views)
If I made a bug, it would detect being in a cage and stop transmitting...
Message 20 of 37
(2,759 Views)
