How to (most efficiently) pass data around
@tonyyyyy wrote:
Does labview has a concept of pointer as in C++?
So i can just use address instead of copy of the whole variables in different VIs or different loops.
The Data Value Reference (DVR) is as close to a pointer as you will ever see in LabVIEW.  As I said before, the DVR is a reference to your data.  You have to use the In Place Element Structure to access the data.  This is done to protect critical paths.
Message 11 of 29
(1,374 Views)
In order to use the DVR "wirelessly", one suggestion is to make a Functional Global Variable (FGV). This is a non-re-entrant VI containing a shift register on a single-iteration loop. Write your DVR to it once (to load the shift register), then use that FGV anywhere in your code and read your DVR from it. Another option is to use a Single-Element Queue (SEQ).
Message 12 of 29
(1,369 Views)
Quick questions:
1. In case of this problem as attached, how to pass it using DVR?
2. how does it (performance) compared to global variables?
Message 13 of 29
(1,347 Views)
@tonyyyyy wrote:
Quick questions:
For that example, I would just use a queue.
Message 14 of 29
(1,343 Views)
hi Cross,
Definitely, you can.
But, what about if I want to use DVR?
How to wire accross 2 loops?
Any way? or , DVR simply doesnt work in this scenario.
Message 15 of 29
(1,337 Views)
Like a Queue, you would have to create the reference before the two loops and pass the reference into the loops.
Message 16 of 29
(1,332 Views)
Here is a very simple code outline of how to pass a queue reference between two loops.
Message 17 of 29
(1,302 Views)
Hey Chris,
Is there a way not to use wire? (wireless ) 😄
Message 18 of 29
(1,291 Views)
Queues and DVRs really are wireless.  Both references are pointing to the same data.
-Jim B
Applications Engineer, National Instruments
CLD, CTD
Message 19 of 29
(1,281 Views)
Thanks Chris & James,
But, any loops that uses that queue has to wire to the queue creator shown in the blue line.
Message 20 of 29
(1,272 Views)
