How to move a numeric display
Id like to know if there any way to move a numeric indicator/(or similar) around the screen to different x,y co-ordinates whilst the program is running,
labview 6.1, window 2000 and xp
(3,056 Views)
Hi Raven,
you should use the property Position to set control position progammatically referred to pixel screen resolution (top left corner 0,0 coordinates).
See example.
Alberto
(3,056 Views)
Yeah thanks everso much that seems to have done the trick 🙂
(3,056 Views)
Here's an example written in the older 6.0.2 version for those that can't open alberto's excellent example. I'm assuming it's excellent, I can't open it. 🙂
Richard
(3,056 Views)
