How to move a stepper motor?
My setup: Labview 7.0 with PCI-7342 controller card and NEMA size 23 stepper motor.
The dilema: I am new to both Labview and stepper motors and I need some basic flow instructions. All I want to do is to have a start and stop button on the panel. Start turns the motor CW and stop will halt it.
I have a test panel using the following block sequence:
Enable Axes
Configure Step mode and polarity
Load Counts/Steps per revolution
Start Motion
Stop Motion
Is this the right sequence of labview functions? I tried this code and nothing happens (of course). Can anyone just give me a quick description as to what Labview code blocks I need to start and stop a stepper motor?
Jeff
(4,102 Views)
First, make sure that you can get motion using MAX. Set board and axis configurations there and save them. Then use Interactive 1D to do a simple move. In Labview, all you should have to do is:
1. Initialize board if needed.
2. Set operation mode.
3. Load target position.
4. Start motion using Multistart or Blend.
(4,102 Views)
the motor needs more current and voltage than your labview card
has on its output. so you need an driver (and, as i recommend a
controler) (if you have time, you can build it yourself, if not,
buy one) in addition to your step-motor. I use the ST L298N and ST L297
if you have a controler, it has normaly inputs for step, direction,
half/fullstep, reset, enable.
you can use digital output lines to control these controler inputs.
i just had the same problem...it wasnt that easy for me as it looked... 😉
first idea is to run the step motor with oldschool hardware wires and
switches instead of labview ...
"sparafucile17" schrieb im Newsbeitrag
news:506500000008000000419E0000-1042324653000@exchange.ni.com...
> stepper motor.
> it.
> Enable Axes
> Start Motion
> Stop Motion
> stepper motor?
> Thanks,
> Jeff
(4,102 Views)
Thanks for your help.
I finally figured out what was wrong. I had actidentally configured the card as a servo motor. Not to mention that I did not initialize the card, so it didn't work after a cold-boot.
The interactive 1D helped a whole bunch! I didn't even know it was there. I had looked in MAX before, but didn't see where I could launch a test panel. But now I know what to do.
Jeff
(4,102 Views)
Thanks for your input, but I actually just had the card settings loaded wrong:
It was setup as a servo motor and I didn't initialize it.
But things are working great now!
Jeff
(4,102 Views)
I'm glad things worked out. Here is a vi that may be helpful. It initializes the board only if it needs to. This should be one of the first steps in your motion vi.
(4,102 Views)
