How to move plots horizontally ?
Hello !
Any hints how to move plot horizontally ?
I have for example six plot on the same graph
and I want to move them individually to a new position
horizontally (y-axis) .
How to do that ?
Any good examples ?
(2,880 Views)
In order to "move" a plot, you must shift the values. Add or subtract the amount you want it to move.
(2,880 Views)
Although I haven't used it yet, you may want to investigate the (new in LabVIEW6i) Y-scale index for a plot.
It looks to me that each plot can have its own Y-scale. In that case you can set the properties range.minimum and range.maximum for each scale (and thus for each plot).
(2,880 Views)
