How to move the scroll bar of table
Thanks for your replies. Inserting data into table is working properly. Now I want to move the scroll bar of table as new data inserted into different rows.
Regards
Shivakumar Singh
(3,981 Views)
Hi Shivakumar
Try the edit position property.
Kurt Friday
www.sciware.com.au
(3,977 Views)
Thanks for your reply. Moving the scroll bar function working properly.
Regards
Shivakumar Singh
(3,974 Views)
You can make use of the EDIT POSITION property node of the Table for moving the scroll bar to the latest line of inserted data.
cheers
vicky
(3,974 Views)
This property doesn't seem to work to make the table scroll in LV8. Has anyone else tried this?
(3,850 Views)
Try using the "Index Vals" property.  I think that will provide what you're looking for.
(3,852 Views)
Hi Shivakumar,
use  the Top Left  Visible Cells  Property Node
kind regards
Mesut Sözüçok
(3,764 Views)
