How to move x scroll bar automatically in the graph?
i want to use x scroll bar for watching all data with fixed x scale.
but when over x scale, I should use mouse to show current data.
It means , x scroll is fixed at left.
I want to fix x scroll at right.
how can i do that?
please reply for this.
thank you
(3,546 Views)
Hi q,
set the X axis min/max so it shows the latest data: the scrollbar will move to the right…
Why do you use the scrollbar when you want to have it fixed? What's the sense in this?
(3,528 Views)
You need to set X axis limits programmatically every time when you update graph data
Property node -> X-scale -> Range -> Maximum, minimum
(3,499 Views)
