How to multiply two vector (dot) and get a matrix?
How to multiply two vector (dot) and get a matrix using linear algebra function?
Message 1 of 13
(6,520 Views)
Are you talking about the outer product?
Message 2 of 13
(6,512 Views)
I tried to multiply two vector using dot product, but it alaways give me scalar, I need to multipy two vector and give me matrix.
Message 3 of 13
(6,505 Views)
I tried to multiply two vector using dot product, but it alaways give me broken wire. I tried to convert it from array to matrix but without any seccess.
Message 4 of 13
(6,504 Views)
Can you attach your VI?
Message 5 of 13
(6,499 Views)
This is the VI, you will find the multiplication at the end, it should give me a matrix.
Message 6 of 13
(6,494 Views)
I only have LV2012 so I can't open your VI. You can backsave it and attach it again or maybe somebody else will have a look.
But there's something I don't understand. You're talking about the dot product of 2 vectors. The dot (or inner) product of 2 vectors is a scalar, not a matrix.
That's why I asked if you meant the outer product.
Message 7 of 13
(6,487 Views)
one of the vector is transposed.
Message 8 of 13
(6,480 Views)
A normal 1D LabVIEW array (single dimension) does not have a direction, so it can't be transposed.
And still, the dot product returns a scalar. Maybe what you want is matrix multiplication?
Message 9 of 13
(6,473 Views)
Yes, matrix multiplication.
Message 10 of 13
(6,467 Views)
