How to multiply very small numbers withot round it to zero ?
Accepted by topic author weaam
I agree with Gerd, nothing wrong here.
  • Where is the program that generates the CSV file? Maybe it uses a format that is too short.
  • Could it be that some units are wrong (e.g. HZ vs GHz)?
  • "Index array" is resizeable, of course. You only need once instance.
  • Rotating an array by zero does not do anything useful.
  • Do you have a link to a website explaining the source of the data and the calculation? (Y values seem to be a nice peak). If the result is supposed to be finite and nonzero, often the calculation can be rearranged or reformulated to avoid an abyss somewhere. (example: when calculating a 3D Rice distribution in the wrong order, you end up with inf/inf, while doing it right gives a nice value).
Message 11 of 12
(617 Views)
Exactly the  units are wrong !
Thank you very much !!!!
Message 12 of 12
(600 Views)
