How to obtain Image Display Control display size?
I've been looking through the forums, but haven't found an answer to this seemingly obvious question:
Is there a way to obtain the x-y size of the display portion of the IMAQ Image Display Control? I can use the Bounds properties from the property node, but that includes the borders, labels, captions, etc.
The goal here is to get the size of the display area only, then feed that to an Image Resize function so that the image will scale with the control.
(2,779 Views)
joeljkp wrote:...Is there a way to obtain the x-y size of the display portion of the IMAQ Image Display Control? I can use the Bounds properties from the property node, but that includes the borders, labels, captions, etc.
This info is given by the Image Area Size property node, a little below. Of course, when you change it, that also affect the borders, labels, etc... but the dimensions are those of the display area only.
CC
Chilly Charly    (aka CC)
(2,767 Views)
