07-22-2010 07:05 PM
Dear all,
I have trouble obtainings the position of the data points from an image. I guess I should explain more here.
What I am trying to do is to anaylsis an image (let's say black and white binary bitmap). The image's background color is white and contains some black shapes objects. I want to be able to generates some points around the edges of those objects so that I can reconstruct the shape using the data points obtained.
If any of you can help me a little, I would appreciate it.
Terence
07-23-2010 02:00 AM
If you mean getting something like this.try the attached vi
07-23-2010 04:48 AM
You can also feed the edge points to overlay multiple points.
