How to obtain unit string from variant?
Hi all,
I am starting to use and like the varaint data type especially in combination with clusters. What I now want to do:
I hold all measured data and states in different physical units and types (DBL and Bool) in one large cluster which is typedef'd.
For communication and storage in spreadsheet-readable files I want to convert this data cluster into a tab-separated string
and use 2 lines of headers in the file which contain the name of the cluster element and the physical unit.
Getting the data converted into a tab'ed string is easy and the names will work too, but I am not sure yet how to get
the unit string out of the variant? There is a function in the openg library that gets the unit out of the varaint but this is
a cluster of two integers. I have no idea how to convert this into the appropriate string. Another issue: The openg function
throws an error if a varaint has no unit (it seems) how can I avoid this and rather get an empty string back?
This is much harder and I probably leave it that way: I would prefer to use the units I defined in my cluster rather than
base units. e.g. I measure a flow in l/min and it gets converted into cubic meters per second which is very unconvenient.
I am afraid there is no easy way to achieve this in an elegant way which works with different clusters and physical units?
Olaf
Message 1 of 12
(5,515 Views)
Hi Olaf,
Sorry but could you post the VI that you made, because is difficult to understand without an example...and I can see if I can help you...
Best Regards.
Matthieu
Message 2 of 12
(5,498 Views)
Here is the graphics of a vi that explains what I am looking for:
Message 3 of 12
(5,494 Views)
One correction: The desired input control for this vi will later be an array of variant not a cluster!
Olaf
Message 4 of 12
(5,486 Views)
Hi Olaf,
It would be great if you can post your VI, better to work...and to have all settings of your VI..
Best Regards.
Matthieu
Message 5 of 12
(5,483 Views)
Here is the vi. It is in 8.20 and you need the current openg variant library.
Olaf
Message 6 of 12
(5,479 Views)
Hi Olaf,
without the "Cluster to Array of VData__ogtk.v" and the "Format Variant Into String__ogtk.v", I can see if there is a possibility to help you...
and I doesn't found this 2 VI's on the web or on the NI Site...
Best Regards...
Matthieu
Message 7 of 12
(5,469 Views)
Hi Olaf,
Now I see your problem but a solution is to use the Label and The caption for the numerical input and work with this...
I think there is no other way to do that...
Let me know what do you mean or if you have another solution...
Best Regards...
Matthieu
Message 8 of 12
(5,465 Views)
@Matthieu Papaux wrote:
Hi Olaf,
Best Regards...
Matthieu
The vi's are freely avaibalbe (open source) and should be in the oglib_lvdata and oglib_string package at:
http://forums.openg.org/
and can be downloaded via the following tool:
http://jkisoft.com/vipm/
Olaf
Message 9 of 12
(5,462 Views)
Hi Olaf,
Best Regards...
Matthieu
Obtaining the labels is no problem, that already works in my code,  but I need to use physical units for some other reasons so I cannot mimick that with using captions instead.
Olaf
Message 10 of 12
(5,460 Views)
