How to obtain vi references in stand alone applications?
Hi all,
My stand alone app includes vi, that obtain graph reference from another vi in such way: Open VI Reference(vi relative path) -> FP -> Controls -> ....  For this application to work correctly, I have to include the last vi in my installer as a supported file, or there's better way?
Thanks.
Message 1 of 16
(4,090 Views)
this is the only feasible way to do it.
BR,
ThSa
Message 2 of 16
(4,077 Views)
Hi Err,
      You should be able to obtain a reference to a VI that's not built into the app - if the VI already exists where the app can find it at run time.  If that's the issue - getting the VI to be included with the app. - it's also possible to trick the compiler into including it by placing it on a diagram inside a case that's never executed.  Smiley Wink
I'm kind of curious, though, how is the sub-VI used?
Cheers.
"Inside every large program is a small program struggling to get out." (attributed to Tony Hoare)
Message 3 of 16
(4,058 Views)
In the main vi I have an object (XY graph) that is programmaticaly controlled by the others vi's.  To avoid passing graph reference to all this vi's as a parameter, I've create vi, that obtain graph reference. Here is the block diagram:
CameraSubVIs.lvlib:Graph reference.vi
But in the app it won't work correctly, because Camera.vi already don't exist (it's startup vi).
Message 4 of 16
(4,054 Views)
Hi Err,
FYI: the picture isn't visible - the URL is local to your PC!
Message 5 of 16
(4,056 Views)
Hi, sorry, here it is:
Message Edited by Err on 08-25-2006 03:02 AM
Message 6 of 16
(4,046 Views)
Well you could put camera.vi inside a case - inside the True case, but wire a constant False to selector.  That get Camera VI compiled with the app and allow this diagram to work, without having to add camera.vi  as a support-file in App. Builder. Smiley Happy
But I'm afraid I'm missing some important idea, specifically:
What is meant by "it's startup vi"?
Gotta go now...
Cheers!
Message Edited by tbd on 08-25-2006 04:08 AM
Message 7 of 16
(4,042 Views)
Thank you. About startup vi - I mean in application specification Camera vi sets as startup
Message 8 of 16
(4,036 Views)
Do you mean camera.vi is the top-level VI?
The application itself so to speak?
Shane.
Using LV 6.1 and 8.2.1 on W2k (SP4) and WXP (SP2)
Message 9 of 16
(4,033 Views)
Exactly
Message 10 of 16
(4,031 Views)
