How to only install Report Generation Kit after Labview install
I have Professional Licensed Labview Test Stand where I wrote a subvi to collect data into excel. The original code  was written by three party integrator. They did not  install Report Generation Toolkit.  Based on the number of issues, I do not want to reinstall Labview 2011 for fear it will not work again.   I just want to add the Report Generation Toolkit. I can download the evaluation package then license that toolkit through the existing license. Any other suggestions?  When I try to modify NI Labview install through the add program under control panel, it seems it was going to do a full install.
Thanks. Greg
Greg
(2,922 Views)
Good morning Shep_Ametek,
I'd recommend to give us a call back, we need to check the serial number and also, since this is an old version of the Toolkit, it is not available for all.
You can call us back at 1-866-275-6964.
Carmen C.
(2,886 Views)
I opened a Service Request  and Andy  found that you  can installed the module post Labview install.
Run the Setup frorm the Cd and Not the Computer Control Panel.
Find Module under "Custom Install" .  It will jump pass Labview Install in a few seconds then show Report Generation Install Prompt.
Gregggggggg
Greg
(2,866 Views)
