How to open a new FP from the menu ring control
Hi Good morning
I need help.I am using a menu ring control which has few options to select,by selecting a option i need to open a new front panel.Is it possible to do it like that,if so pls guide me.
Thanks in advance
Message 1 of 10
(3,561 Views)
Hi Veeru,
See to the attached LLB, you ll get an idea. Smiley Happy
- Partha ( CLD until Oct 2027 🙂 )
Message 2 of 10
(3,547 Views)
Hi partha
Thanks for your mail, I need to have main front panel remain open and additionally the newly opening front panels.Also is it possible to do without using the Event structure.
Message 3 of 10
(3,542 Views)
Hi Veeru,
you can also load the other vi´s dynamically, so that you program is more flexible. Don´t you have the Event Structure or whats the reason behind not using it?
Mike
Message Edited by MikeS81 on 06-26-2008 04:06 PM
Message 4 of 10
(3,529 Views)
Thanks Mike
Actually i am using event structure in some part of my program, previously i got a suggestion that not to use more event structure,thats the reason i thought i will use with other possible methods.
Is it possibel to do in any other methods.Recently i started learning some interesting things in LabVIEW,thats the reason often i post questions.
Message 5 of 10
(3,526 Views)
Hi Veeru,
one FP per vi is ok. You can simply add the new events to your existing event structure.
Hope it helps.
Mike
Message 6 of 10
(3,522 Views)
Thanks Mike
So you mean i cant open more additional FP from main VI,sorry if i misunderstood.
Message 7 of 10
(3,517 Views)
Hi Veeru,
sorry, i meant one Event Structure per Front Panel is ok. Smiley Happy You can open it like shown by Partha or you load the vi´s dynamically.
Mike
Message 8 of 10
(3,514 Views)
Thanks Mike
Message 9 of 10
(3,510 Views)
Hi Veeru,
You can open multiple FPs from the Main VI either dynamically or using CS/ES also. Smiley Happy
Maybe you can try out the option in the VI Properties setting the window to be floating instead of Modal [which I ve set in my VIs].
Or you can try out Mike's suggestion using VI Server >> Run VI method or Call by Reference node (in theApplication palette).
Message 10 of 10
(3,485 Views)
