How to open a subVI on a click of a button
i have a program to run a subvi from a main vi..the problem is how can i link a button click to open a subvi?
thank you
(4,335 Views)
Hi shafiesani,
there are different capabilities.
- You can place the subVi into your code to run it. Set the VI property to open when called.
- You can open a reference to your VI, start it with a invoke node, open it with a property node and ...
Hope it helps.
Mike
(4,328 Views)
thx..i forget to mention that the subVi must run automatically without closing the main VI..is that possible?
(4,324 Views)
Launch the vi dynamically in to memory so that it will run in a new thread. This could be achieved in two ways,
1) using VI server
2) using the "Call By Reference Node"
Regards
Guru (CLA)
(4,314 Views)
i made a similar diagram exactly like Guru and mike...but i keep getting this message..eventhough the VI path is correct
Message Edited by shafiesani on 03-03-2010 05:56 AM
(4,301 Views)
post your code and the subvi that you wish to launch so that some one can help you out 🙂
Regards
Guru (CLA)
(4,284 Views)
Instead of "\" have you used a "/" or have you defined the filename with some special characters?
Message Edited by muks on 03-04-2010 10:50 AM
(4,259 Views)
