How to open same application more than once, when one application is running
Hai,
          After creating EXE, I will start running the application, when this application is running, I need one more instance of this application to run. How to do this ( Lab view is not allowing to open one more instance, I am using 7.1 version ).
Prashanth. M
(2,934 Views)
tried copy and rename your exe?
Greetings from Germany
Henrik
LV since v3.1
(2,925 Views)
Hai Henrik Volkers
        Is there any option other than what you have suggested.
Prashanth. M
(2,925 Views)
pappu wrote:
...      Is there any option other than what you have suggested.
There's the option of adding the following to your .exe's INI file:  allowmultipleinstances=True
Other posts in this forum cover have discussed its use.
Fading out. " ... J. Arthur Rank on gong."
(2,906 Views)
Hai Donald,
         Thanks for your valueable suggestion.
Prashanth. M
(2,888 Views)
