How to open up multiple front panel screens with one program?
I have 3 subvi's I have created and want to open one at a time. The 1st vi relates to the 2nd and the 2nd to the 3rd. All they do is create settings for the next vi. I need it to open, put in settings, close, then open the next vi. I tried putting each subvi in a flat sequene; I got them connected but it gives me errors. I attached three parts of the code, one vi is missing because it wouldn't let me attach it. Hopefully you can follow what I'm doing. Thanks for the help.
(3,044 Views)
Also, part of the programs will be wrong as I have been programming on the road and haven't been able to test with the DAQ as I go through each process.
(3,043 Views)
Accepted by topic author Relient
For future reference, zip up all of your VIs and post the zip file.
Anyways, what you need to do is edit the VI properties (File->VI Properties).  Go to the Window Appearance and click the Customize button.  You will see an option to "Show front panel when called" along with a "Close afterwards if originally closed".  You need to enable those options.
You shouldn't need the sequence structure if you are wiring up from one VI to the next.  Make sure all of your inputs are wired.
(3,038 Views)
