How to pass a null pointer trough a "Call Library Function Node" ?
Hello.
I'm developing DLL's and using them in LabVIEW trough the "Call Library Function Node" VI.
I wonder if isn't possible to pass parameters to a function like this:
void getArray(double **array);
Where I just want to pass a NULL pointer in the input, and just in the output I get the array that was builded in the DLL code.
Example of a call to the funtion in C++:
        double *array = NULL; //declaration of the array
        getArray(&array); //call to the function
I've looked to the examples in the LabVIEW directory (ARRAY1DHandle.vi, ARRAY2DHandle.vi, ARRAY3DHandle.vi),
as well as the source code, but in everyone of them I already know what is the size of the outpu array, but I've situations that I don't know that,
because that is done in the DLL.
I appreciate anything that could help me solve this "limitation", or mine or LabVIEW's.
Thanks.
Nelson Neves
(3,924 Views)
Hello Nelson,
I tried to find your email address but was not successful.
I am developing a PocketPC application and need to develop a simple DLL that can be called from my code.
Please contact me regarding this opportunity
Guy R. Hughes
Controlink Systems, LLC
link@eos.net
(3,887 Views)
Hello Guy
When you are creating a DLL for LabVIEW PDA Module use, you need to create two DLL's:
   - one builded for PDA (ARM), you can use EVC to do that;
   - other builded for PC (x86), you can use Visual C++ to do that. NOTE: I've tried Borlad software to do this one and it doesn't works. I believe that you need to use a Microsoft made software to do this.
I leave you this link to one thread that should have all the information tha you need to do this.
LabVIEW PDA reports COREDLL.DLL error when using Call Library Function Node
I hope this help you.
Nelson Neves
(3,872 Views)
I hope this can help.
(3,862 Views)
Hello Nelson,
In all fairness to the forum, please contact me privately at link@eos.net.  (I do not have your email address).
I am interested in contracting your services if you believe you can help me.
Guy Hughes
(3,843 Views)
