How to pass a structure (not a pointer to the structure) to a dll
I am using Call Library Function, trying to pass a structure to the function in dll.
The function is like this:
        int DllFunc(int a, DLLSTRUCT dllstruct);
The structure is simply like this:
    typedef _DLLSTRUCT
       int a;
       int b;
       char c;
    } DLLSTRUCT;
I created a cluster like the structure, and tried to use "Adapt to Type", "Handles by Value" to pass the structure to the dll function. LabVIEW crashes.
I guess it actually passes in the pointer to the structure, not the structure.
Is there a way to pass in the structure to DLL?
Otherwise I will have to create a wrapper function.
Thanks for any input.
Message 1 of 9
(3,841 Views)
Using a cluster is the correct method, and Adapt to Type should be what you use. Take a look at the "Call DLL" example that ships with LabVIEW. What datatypes did you use for the individual cluster elements?
Message 2 of 9
(3,821 Views)
Thanks.
I took a look at the "Call Dll" example, the Cluster example has Function Prototype: void CLUSTERSimple(TD1 *input, TD1 *output); in which input is a structure pointer.
The Function I am trying to access is passing in the structure, Not the pointer, such as void CLUSTERSimple_str(TD1 input, TD1 *output); can I do this?
Message 3 of 9
(3,812 Views)
Unfortunately, clusters are always passed by reference, not by value.
Message 4 of 9
(3,791 Views)
Then I think I will have to use a wrapper function.
Thank you.
Message 5 of 9
(3,783 Views)
Your cluster is 72 bits, right?
Shame it's not 64 or less because you could then trick LV into wrapping your data in a U64 (using the cast function) scalar and pass that (willingly telling LV to pass it as something other than it actually is).
I don't see a way of passing more than 64 bits by value with the call library node.
Looks like you really need a wrapper DLL.
Shane.
Message 6 of 9
(3,759 Views)
Yes, it is more than 64bits.
But thanks for the trick.
Message 7 of 9
(3,743 Views)
How could i do this Wrapper function?
Respectively how could i handle with the following problem in C#
i have this in my header-file of the SharedLib.h
typedef struct {
	LVBoolean status;
	int32_t code;
	LStrHandle source;
	} TD1;
void __cdecl IP_Supply_GET_Current(TD1 *FehlerEingang, LVBoolean *Start,
	TD1 *FehlerAusgang, LVBoolean *End);
long __cdecl LVDLLStatus(char *errStr, int errStrLen, void *module);
 and try to make a project with this rudimentary start:
namespace IP_GET_Current
 /**   interface TestInterface
      Boolean status{
        get;
        set;
    public class Class1 /**: TestInterface**/
        [DllImport("C:\\SharedLib.dll", EntryPoint = "IP_Supply_GET_Current", ExactSpelling = false)];
        static extern unsafe void IP_Supply_GET_Current(Int32 code, Boolean Start, Boolean End, Int32 code);
        public struct TD1{
            Boolean status;
            Int32 code;
        Boolean Start;
        Boolean End;
        public Main()
            IP_Supply_GET_Current(3,true,true,2);
How can i start to solve the problemß
Message 8 of 9
(3,444 Views)
Arphex,
I am not sure what you are asking for.  Are you looking for help writing the wrapper?  Are you trying to write a dll to call from LabVIEW?
If this is specifically related to C# or .NET, you may find better resources at the MSDN forums, since this is a primarily LabVIEW forum.  However, if you can help us understand a little bit better what you need help with, we may be able to help you as well.
Thanks, and good luck!
Drew T.
Camber Ridge, LLC.
Message 9 of 9
(3,420 Views)
