How to pass array of clusters from Teststand to labview DLL
Sara -
You do not have to have the LabVIEW Development Environment installed to call VIs from TestStand. You can call VIs from TestStand using the LabVIEW Run-Time Engine. Please see the LabVIEW Adapter Configuration Dialog Box Help topic for information regarding where to specify that TestStand calls VIs using the Run-Time Engine.
Also, please see the Using a LabVIEW Run-Time Engine or Other Executable Server section of the Using LabVIEW and LabWindows/CVI with TestStand manual.
Hope this helps.
Manooch H.
Message 11 of 12
(559 Views)
Thanks a lot. That will probably fix my problem.
Message 12 of 12
(555 Views)
