How to pass data to a spesified memory location
      We want to pass 1D data into a specified memory location in Labview.  Originally we use (Call library fuction node +Labview.exe: Moveblock).  However its exe application only works on the machine with labview installed, because it looks for labview.exe.
     Is there some ways to perform this function to pass 1D data into a specified memory location, which is preasigned with address and size ?
Zhong Cao
(2,887 Views)
In the Call Library Function Node try typing LabVIEW instead of LabVIEW.exe. That should resolve in the run-time engine on a machine without LabVIEW installed. It will in fact call into the run-time engine itself.
Jarrod S.
(2,862 Views)
