How to pass parameter to a vi when run with reference
i have a VI which executes another vi by opening a refernece to it and using the method "Run Vi". (see attached screenshot.
My question is now: How can i pass the parameters to the vi that is executed?
thx for the help
(3,524 Views)
in the example finder there is a very nice example, called "plugin example.vi". This should be a good start for you Smiley Happy
greets, Dave
Greets, Dave
(3,521 Views)
But when use the "call by reference"-style then i dont have the option "Wait until done = FALSE" anymore.
Currently i just pass the parameters with a global variable.
(3,517 Views)
Can you solve this problem with a second independent loop? Like producer-consumer style...
greets, Dave
Greets, Dave
(3,512 Views)
Did you try out with the Get/Set Control Values methods ? I think it ll suffice.
- Partha ( CLD until Oct 2027 🙂 )
(3,502 Views)
