How to pass pascal string pointer to Delphi DLL?
Do you finally have a solution to your problems?
Fabrice
Message 11 of 13
(1,828 Views)
Topic UP,
I have the same problem but no solution with previous posts.
I've tried to Use Length + convert string to U8 array and Pascal string pointer without success ... any advice ?
Message 12 of 13
(1,593 Views)
The most common method is to define the DLL function parameters as CStr.When you call the function node,
double click and set the parameters as C String Pointer.As Below
Message 13 of 13
(1,575 Views)
