How to pass sensor data from NI Controllers cDaq-9132 to my Host(VPS)
My task is building a monitoring program(web) using LabView and NI devices (cDAQ-9132 controllers).
  • I have 4 cDAQ-9132 controllers
  • 1 VPS that installed Labview and I wanna deploy my web here.
1: I don't know how to pass sensor data from the controller to my LabView programs(on VPS) via internet environment.(is it possible if I use simulator device)
2: I don't really know which technology that I should use: LabView web UI builder, LabView web module(LabView NXG), or something like that ...
I'm very grateful if anyone knows about this or another suggestion.
(3,406 Views)
can anyone help me?
(3,365 Views)
Hello dandynamite,
How are your CDAQ 9132s and 9135s connecting to the network?  Are they currently connected through Ethernet connection?
If you have these devices connected to your network all through the same subnet you'll be able to find them in NI-MAX under "Devices and Interfaces" >> "Network Devices".  At this point you'll be able to use Test Panels to simulate your system further.  I don't see a reason why this couldn't be done by simulated devices at first just to test your system architecture.
Tyler O.
(3,352 Views)
First, thanks for your help.
Is this possible even Ni controller and my VPS are not on the same subnet?
So that I just connect my controllers to the internet via wifi or ethernet cable.
The rest of work is connecting to my online devices from my VPS. So how my VPS recognized my devices without any identification
And finally, can you give more detail instructions because of so many options when I open Network Devices.
I'm looking forward to hearing from you
(3,346 Views)
please tell me if something goes wrong with this architecture.
(3,343 Views)
