How to pass string from labview to c#
Hi
I have used .net assembly to use a dll in c#.
The communication part is fine and I can pass the parameters from c# to labview but one of the functions should read back a string from labview
WriteSingle(string in, out string);
And I see nothing goes back to c# . Could you please help me with this . How should I pass the string in LabVIEW that can be recognised in c#
(4,602 Views)
I would greatly appreciate any help
(4,575 Views)
Have you done a search or gone through this?
White Paper on DLL access
Can you post how you've configured your Call Function Node?
(4,569 Views)
I assume that you mean that you have compiled your LabVIEW code into a DLL, which contains functions that you are calling from C#. You need to allocate the output string in the C# code before you call the DLL. LabVIEW will not allocate a new string, it will simply use the space provided to it. If you pass a zero-length string, then what you get back will also be a zero-length string. I don't know enough C# to tell you how to do this allocation, but I'm pretty sure others have asked the same question on this forum and some searching might turn up the answer.
(4,563 Views)
let me explain it step by step
1. I made a dll using .NET assembly
2. I added the dll to the references in c# and here is the difinition for it
public static void singleRead(out int element)
3. Then I call the function as below :
int m;
singleRead(out m);
format of element is I32 in LabVIEW and everything completely matches but I can't read data back from LabVIEW to c#. so when I run the code m is zero
I can completely communciate through that dll from c# to labVIEW and I can send parameters as input from c# to labVIEW but for the other way seems like something is missing and I can't read it back
I forgot to mentiond I changed my output from string to I32 because I thought it might fix the problem but I still se the issue
(4,552 Views)
How did you configure the VI parameters when you built the .NET assembly? A screenshot or two would help. Any parameters that will contain new values when they return need to be passed by reference, not by value.
(4,537 Views)
